Ximo
New Member
I have more photos, but this program tell me are so large to attach to this chatFrom the first photograph, it seems as if the keel joint is much higher than where this major fault lies.
A quick search this yacht was built either in Taiwan or Thailand under the control of a New Zealander.
Could the keel be in two parts that are bolted together and this joint may have had corrosion problems?
The leading edge seems to have dropped, so has the boat run aground on rocks and fractured the keel?
The smooth start of the crack is odd and then an area of massive corrosion, but aft the keel looks perfect. If the keel was in one piece, then during the casting it might have had a double pour of molten metal and an area between the 2 pours had some slag or cooling that allowed water to enter and corrode.
These are just my thoughts.
It is very difficult to judge from the limited number of low resolution photographs. Any chance of more higher detailed photos?
