TiggerToo
Does anyone know if there are guidelines for what torque to apply on keelbolt nuts?
I have read on the internet, so it must be true, that excessive torque can compress GRP laminate and turn it into GRP crumble.
Foot on 600mm wheel brace, sitting on floor, back against bulkhead...................
?? Do the math.
A 5/8" bolt will have a clamping force of about 16,000 pounds. The area under the nut is about 0.35 in2, so the compression is about 45,000 PSI. Fiberglass typically has a compression strength of about 20,000 PSI, so you will easily tighten the nut right through the fiberglass. I have done this in testing, even with plain bolting washers, many times.
Of course, a thick (not bendable) washer or backing plate increases the area, and you need to stay below a safe working load (~ 3000 psi), so you need at least 16,000/3000=5.3in2 in this case, about 2.7" diameter, or about or at least 4 boat diameters. 5 diameters is conventional wisdom, since the loading will include shear.
"As part of launching procedure, check all keel bolt nuts for tightness to 90 foot pounds before the boat is lifted out of the cradle."
I can’t remember precisely but I think I used to torque then to somewhere between 150 and 200 ft. lbs. using a torque wrench. The bolts on that boat used split ring lock washers under the nuts.
http://www.cruisingworld.com/dont-let-loose-keel-bolts-ruin-your-day
If you can get a 1" drive torque wrench and the 1 1/2" deep socket you can do it yourself. You'll also need an extension(s) long enough to clear the floor boards.
I've tightened mine both our of the water and in the water.
The information I got from Catalina calls for 235 lb-ft torque.
Nick Wigen
Ursa Minor #178 FK, 3-Cabin
Olympia, WA
http://catalina42discussionforum.yuku.com/topic/1658/Keel-Bolts#.Vy2-NOQgnx0
I have a 30' Sabre, and the manual states the keel bolts should be checked and torqued (to 90 foot pounds), as necessary.
From the manual:
"...Occasionally, water from the bilge may seep through this crack when boats are hauled. This would be due to a slight leak at a keel bolt, which can be readily be overcome by tightening the keel bolt nuts. As part of launching procedure, check all keel bolt nuts for tightness to 90 foot pounds before the boat is lifted out of the cradle."
http://www.sailnet.com/forums/gear-maintenance/65330-re-torquing-keel-bolts.html
Torquing Bolts
________________________________________
First start with the bolt size.. typically manufacturers use a bolt size appropriate to the load they will encounter with some safety margin. You would be amazed by how much linear force a thread will transmit because of the mechanical efficiency. 90 ft-lbs is a literally a boat load of force.
Using the simple calculator here
http://www.engineersedge.com/calcula...orque_calc.htm
a 1" bolt @ 90 ft-lbs transmits 960 lbs of linear force. If you have a half dozen, that is close to 3 Tons of clamp.
Torque with caution, & not all at once.
TD
On my C&C30 Mk 1 I believe there are 4 keel bolts (maybe 5). What I'm sure of is they are 1" diameter and are torqued to 350 ft lbs.
To actually torque them to specs, you'll need a deep well 1-1/2" socket (if the bolts are 1") and a torque multiplier or one heluva big torque wrench. I actually bought a torque multiplier and the deep well socket to allow use of my 1/2" torque wrench with 3/4" adapters to fit the socket and torque multiplier. It cost me about $175 for the tools.
If I had it to do over again, I'd let the yard do it, although I don't think they had the tools anyway.
They really needed it. They were just beyond hand tight and the C&C smile required yearly patching. Since torquing to specs, the smile has not reappeared.
http://www.sailnet.com/forums/gener...3927-1983-c-c-29-mk11-keel-bolt-question.html
