Thedigger
Active Member
Hi, I am restoring an insurance write off after the fin keel ran aground. I removed the keel and had to straighten the keel bolts which bent and sistered to new bolts at the front. I filled the keel holes in hull with fibreglass now have to drill new holes for the bolts. What sort of drill bit and drill should I use. The holes will be 22mm and the hull is about 50mm thick?
