KAMD43
David_J
29 Sep 2003
South East
Not noticed before but there is definitely a trace of fuel oil or lube oil in the cooling water coming from the exhaust. There is that streaky hint of an oil slick drifting away on the surface of the water in the vicinity of the exhaust outlet. Might be bad news, especially as the engine has only done 60 hours.
This was only on start up but did not run it long enough to see if it was like that when hot. Does this happen on this engine when cold? valve guides or something?
What do you think?
Moose
1 Nov 2001
West Sussex, Boat in Chichester
All engines seem to do this a little bit. I get a minute trace of oil when I start them up but nothing when they are running (63p's) I do now get a large amount of neat engine oil being pumped out of the bilge when I step on the boat though/forums/images/icons/smile.gif
[2068]
19 Sep 2002
probably just a bit of unburnt fuel. Most VP non-edc engines will do this to some degree. Shouldn't be a big slick, tho...
Renegade_Master
27 Jan 2003
Spain
60 hours David gosh thats not a lot, ...my KAMD43's try 2000... Cant say I have noticed any such emmissions from mine.
When you gonna cruise down to see us then? Clive
<hr width=100% size=1><A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
David_J
29 Sep 2003
South East
Thanks to all.
No, 60 hours is not much.
Only had two decent runs. Brighton to Solent.
Boat lets us down both times.
First time lower helm steering wheel fell off and flybridge power connection fell off at the engine.
Second time a high pressure injector pipe fractured. Diesel everywhere. We came home by car.
I am told these "teething troubles" not uncommon in boats up to 50/60 hours!!!!!!!!
Renegade_Master
27 Jan 2003
Spain
"First time lower helm steering wheel fell off ".... teething troubles??? good job it wasnt a new car then, kinda need the steering wheel I reckon.
Sorry David thought you were the other David with a J hes got an S37
