Kad44 edc power connections
mattnj
26 Jul 2007
www.red-data.co.uk
Kad44 edc looks like the main red/black input/power cable goes to the port side quite low down / under he engine. I can see it and get to the nuts but they are a bit stiff/corroded.....they need to come off...am I going to shear anything off if I keep turning or do I need spanner behind....it's hard to access and I can't see.
it’s a isolated stud in a plastic block attached to a bracket. One pictured was snapped most of the way down the stud
I replaced them for something similar
you might not have those blocks at all if you’re kad44 p-c in which case….the cables are going to the starter
