Andysim
New Member
Can anyone solve my mystery… I have a 96 Fairline Targa with KAD 42. running approx 1000hrs. They both run up to temperature around 78deg C at around 1500RPM. The Port engine stays marginally cooler as it has the water cylinder connected. I then throttle up to around 2400 RPM just past the supercharger and the turbos take over and within 2mins the overheat alarm comes on the starboard engine. They will run all day with the superchargers. I have swapped the thermostats on the engines. She has been lifted and the outdrives checked and tested. Impellers replaced on raw water pumps. I have checked the temperature of the engines while under way using an infa-red laser thermometer both engines at 2300RPM hold steady at 85Deg C on the thermostat housing. Which suggests to me that the engine is not overheating. The oil is good and the water level is good. What else can i check?
