KAD32 Ignition Issues
bc22
New Member
18 Jul 2022
Hi all
I had to call out Seastart last week as my S23 fitted with a KAD32 failed to start on selection of ignition. She has always been a good starter!
After a jumpstart and back to the marina, I decided to start with a replacement Volvo Ignition switch as I have also had a few incidences where she would not turn off when the key was rotated to the stop position.
On comparing the new start switch with the existing one, both seem to be functioning correctly when tested with a multimeter.
2 questions.....
Question 1) Following the Volvo wiring diagram, and using other helpful posts on this forum, you can trace the power supply in to the ignition (Red) and then out to the stater motor (Red/Yellow). The Volvo diagram shows a "spliced connector" as if it is deliberately there for some reason, but does not show what it could go to. On my boat, the spliced connector IS used, and goes via red and black cables to "something?". Disconnecting the red and black cables and reconnecting the spliced section, the boat starts fine!! This makes me think that there is a short in the circuit created by the red and black cables. I just don't know what it goes to? A safety system? A relay or sorts? The trouble is, these cables are only live when the starter motor is selected to on. Any ideas?
Question 2) Once started, all is fine. On occasion, when selecting the ignition switch to stop, the engine does not stop. It can take several attempts to. As above, I have fitted a new ignition switch, so this is not the case. My question; Is there an equivalent "stop relay", to stop the engine? Or, is there something similar? If so, where is it located? Whatever it is, something is not right and needs fixing before it become less intermittent and more permanent!!
As always, any help or experience gratefully received.
Ben
Intermittent starting issues on two kad engines I know of (one my own) were both associated with the starter relay in the black box on top of the engine. In one case was just a corroded and loose terminal.
I guess stop solenoids can become faulty but again electrical connections are the first thing to check.
Hi MartynG
unfortunately none of the above so far. All connections have been switch cleaned and checked. Have also checked the Start Solenoid. Will have a think about replacing the stop one after one last clean.
Check....
Do you have a faulty neutral microswitch on the throttle lever
Faulty thermo trip switch in black box
Faulty engine start relay switch in black box
These are things I have experienced with KAD 42's and imagine would translate to 32's
