boy boater
Active Member
The recommended change period for the fuel filter and fuel pre-filter on my KAD32 is every 200 hours/at least once a year.
The engine has done 30 hours in the 12 months since I last changed both filters.
The pre-filter has a tap at the bottom for draining off any water found in the fuel, when I tested this I found none.
In view of the low hours run, i.e 30 vs 200, what problems, if any, can I expect from leaving it for another 12 months before changing the filters assuming I don't exceed 170 hours running time in the interim?
Do filters degrade with time as opposed to usage, i.e. throughflow?
