Somerset Taz
Hi All,
I have a number of strange electrical issues that might all be related. First, the port engine tacho works fine until the starboard engine is started, then the port tacho seems to drop and then get stuck at around 1100 revs. When the port engine is running on its own (tacho reading correctly) and I beep the trim switches (switches are on the port throttle leaver) the tacho drops about 500 revs on the scale then recovers when the trim switch is released. When both engines are running the starboard tacho is unaffected by the trim adjustments. Also recently, the port engine has started popping the main engine fuse. This does not seem to happen when the supercharger is engaging or disengaging. In all other respects the port and starboard engines perform very well - they start first turnover, are able to reach the spec WOT, no cooling issues, alternators 14v etc (engines approx 250 hours and regularly professionally serviced). Could the throttle and/or trim switch be causing these issues? Any thoughts out there from the gurus gratefully received.
