alt
Friend bought a new (to them) boat today - Regal 2250 with a KAD32.
Everything ticked the boxes with the only issue being that the power steering pump didn't seem to be working. Friend is an auto mechanic so this didn't put him off and bought subject to adjusted price.
Before we rip things apart...
There was *some* issue with the steering pump leaking (or the hoses) in the past (we we met the owner some time ago) but that's all we know.
The steering is the same with engine running / not running.
The pulley is spinning fine.
We plan to disconnect the steering cable at the steering cylinder tomorrow to check if it's the cable.
When re-assembling the steering pump, would it be possible in any way to do so wrongly? ( ie. wrong hoses in wrong places) - I don't think this is possible as if the pump is as usual auto pumps, there's 1 high pressure hose and 1 low pressure hose with different fittings.
I wonder would the wrong oil cause this issue? (I know it can on cars) - Can anyone confirm it's bog standard ATF that goes in there?
Anything else obvious to check?
As mentioned, this is a thing that my friend should be able to solve but any additional tips would be greatly appreciated.
