Momac
One of the two bolts at the lower end of the bracket supporting the turbocharger and its spacer were found under the engine during my routine engine bay check today. I perhaps dont look so closely under there very often so the bolt may not have fallen out today.
The threads in the bolt are slightly damaged and the bolt doesn't fit through the spacer ...
looks like the hole on the spacer has always been too small as it looks like the bolt had tried to cut a thread into the spacer.
The spacer looks too short for the gap between the bracket and the engine.
I will buy a new bolt and spacer if the VP price is sensible. If not the threads will clean up and washers are cheap.
In the meantime need I be worried about running the engine?
We are on the river and will only be going slow.
