KAD300 - Torque (Nm) of exhaust manifold studs / bolts?
alt
24 Oct 2006
Éire
As above, can anyone remember? Thought I got the info before but can't remember where from or what the spec was!
Unless otherwise stated the torque settings for each size of bolt is given right in the front of the workshop manual concerned (Engine Body IIRC). I am not at the right computer to pull it out, but as the workshop manuals are readily accessible I'm running on the presumption you have them. Otherwise PM @Mr Googler for his forum copies on onedrive
Thanks Bruce, yeah I have them, but searched them and couldn't get a figure. Someone on a FB forum stated 40Nm which rings a bell!
Page 6
Tightening torques
Tightening torques for vital joints that must be tightened
with a torque wrench are listed in workshop
manual “Technical Data”: “Tightening Torques” and
are contained in work descriptions in this Manual. All
torques apply for cleaned threads, screw heads and
mating surfaces. Torques apply for lightly oiled or dry
threads. If lubricants, locking fluid or sealing compound
are required for a screwed joint this information
will be contained in the work description and in “Tightening
Torques” Where no tightening torque is stated
for a joint use the general tightening torques according
to the tables below. The tightening torques stated
are a guide and the joint does not have to be tightened
using a torque wrench.
Dimension Tightening Torques
.............Nm...........lbt.ft
M5............ 6 .............. 4.4
M6........... 10 ............ 7.4
M8 ...........25............. 18.4
M10........ 50.............. 36.9
M12....... 80.............. 59.0
M14 ......140.............103.3
deviations are:
Tightening torque
Cylinder head screws ........................................................... See next page
Main bearing screws (early model)
31 series (up to engine number 2203118631)
41 series (up to engine number 2204144595)
42 series (up to engine number 2204203834) .................. 80 Nm (59.0 lbf-ft) + 60° in one movement
Main bearing screws (late model)
31 series (as from engine number 2203118632)
41 series (as from engine number 2204144596)
42 series (as from engine number 2204203835)
32/43/44/300 series ........................................................... 60 Nm (44.2 lbf-ft) +90° in one movement
Con rod nuts ......................................................................... 113 Nm (83.3 lbf-ft)
Flange, front camshaft bearing ............................................ 24 Nm (17.7 lbf-ft)
Gear wheel, camshaft .......................................................... 85 Nm (62.6 lbf-ft)
Gear wheel, pump drive ....................................................... 24 Nm (17.7 lbf-ft)
Shaft stub for idler wheel, gear train .................................... 24 Nm (17.7 lbf-ft)
Pump housing, lube oil pump ............................................... 24 Nm (17.7 lbf-ft)
Bracket, lube oil pump ......................................................... 24 Nm (17.7 lbf-ft)
Idler wheel, lube oil pump..................................................... 24 Nm (17.7 lbf-ft)
Bearing cap, rocker arm shaft
31/32/41/42/43 series ........................................................ 48 Nm (35.4 lbf-ft)
44/300 series ..................................................................... 24 Nm (17.7 lbf-ft)
Sump .................................................................................... 15 Nm (11.0 lbf-ft)
Drain plug, sump (where appropriate) .................................. 60 Nm (44.2 lbf-ft)
Timing cover ......................................................................... 24 Nm (17.7 lbf-ft)
Valve housing (31/32/41/42/43 series: upper) ..................... 8 Nm (5.9 lbf-ft)
Inspection hatch for valve lifter ........................................... 24 Nm (17.7 lbf-ft)
Hollow screw for adapter / oil filter ....................................... 50 Nm (36.8 lbf-ft)
Hose connection for oil filter ................................................ 50 Nm (36.8 lbf-ft)
Nipple for hose connection to oil filter ................................. 60 Nm (44.2 lbf-ft)
Flywheel ................................................................................ 65 Nm (47.9 lbf-ft) + 60° in one movement
Bell housing .......................................................................... 48 Nm (35.4 lbf-ft)
Vibration damper, fixing screws ........................................... 28 Nm (20.6 lbf-ft)
center screw for hub.......................................................... 180 Nm (132.7 lbf-ft)
Injection pump, delivery valve holder .................................. 40 Nm (29.5 lbf-ft)
Nut, injection pump flange ................................................... 90 Nm (66.3 lbf-ft)
Injectors, nut for stud ........................................................... 24 Nm (17.7 lbf-ft)
Turbocharger, exhaust pipe flange ...................................... 45 Nm (33.1 lbf-ft)
Tighten screws in 5 stages as per schedule:
1:st tightening 30 Nm (22.1 lbf-ft)
2:st tightening 60 Nm (44.2 lbf-ft)
3:rd tightening 100 Nm (73.7 lbf-ft)
4:th tightening 90° in one movement
Final tightening 90° in one movement
Spotted that in my own manuals, no specific mention of the exhaust manifold studs / bolts!
IIRC they are M10 so as per above 50Nm. The stud only goes in finger tight. You dont torque that down, it'd be counter productive, just the nut
Bugger, I only tightened to 40Nm.
I wonder what I have to strip to get access to them all.
I'll measure the thread diameter tomorrow morning, I know the nuts are 15mm
9/16th ! Trust an imperial bolt to muddy the water. Treat it as a 10 if that is what it measures. Though to be perfectly frank those bolts are not critical and an approximation will do. I do mine up by feel. The standard length of a spanner is a good feel indicator of where the torque should be. I wouldn't go to town on it personally.
They're 9/16th? Was almost certain they were 15mm!
I ask because when I started the engine earlier, I saw 1 drop of coolant over 2 exhaust manifold gaskets. I wiped them clear and they didn't return, but when I inspected after, I spotted 1 drop of coolant on the side of the block.
I'm certain there wasn't any coolant there before. I didn't spill any coolant when filling (a few weeks back).
I also noticed that on one of the gaskets, on the exposed bit of it (looking down from the top of the engine), went rusty!
I tightened to 40Nm, but used an extension.
I think it may be safer to not do anything until I can run the engine and test again (and let the temp get up a bit) - I'm waiting on a new exhaust elbow / turbo clamp.... my current one is dodgy so needs to be replaced.
Started in the middle and worked my way out.
The drip was coming from either cylinder 2 or 3 (1 being at the stern, turbo side).
I'm tempted to take things apart tomorrow to check torque again but don't know what they should be at! Currently at 40nm... do I risk 50nm?
Thanks. Going to tighten to 50nm and see if that helps. I can only get a torque wrench to about 8 of them without dismantling so ill see how much of a turn I get on the wrench and go with that for the spanner
Tightened everything up to 50Nm and was able to run at idle, no leaks! I'll launch next week to run under decent load (boat hasn't been polished etc. yet) and hope for the best.
Fingers crossed I just didn't tighten enough.
