KAD strainer basket leaking.
BruceK
8 Feb 2015
Conwy
Port engine strainer leaking water through the threaded lid. There is no seal for these things are there? I have a seal on the basket and a cap on top that. But water is getting past and leaking out the lid. Seals, baskets etc all new as of this season. New strainer housing required?
Focus on the seal around the basket - it’s the middle section of the lid pressing down on the black rubber basket seal that makes it waterproof, not the threaded bit.
ta. I'll check the seal and grease if need be. Not had it leak before that I had noticed but on inspection the water pump housing is showing signs of corrosion so it must have been.
