KAD 44/300 Valve Adjusting
spannerman
30 Nov 2002
For those of you running either of these two motors and are feeling ripped off by their local Volvo specialist, I thought I'd put up the method of adjusting the valves for those who would like to do it themselves. I'd only recommend this for those who have done valves before on ordinary 2 valve per cylinder motors, especially if you are familiar with the 40 series Volvos.
There is a lot of stuff to remove before you can get to the valves so here goes;
Remove the oil filter, then its mounting bracket and carefully bend it out of the way on its flexible hoses. Remove engine main harness at fuse box and bracket with the trim pump fuse and power cables on top of the inlet manifold, if they are in the way.
Then disconnect the pipe between the filter and lift pump and remove the flat plate supporting the fuel filters, ( you can disconnect the plug from the fuel ECU if it makes it easier, you won't lose any data, just carefully pry the flat red plastic clip away from the plug and it will eject the connector from the ECU) now you can swing the filters out of the way, but turn off the fuel if poss or it will syphon out.
Now remove the injector pipes from the pump starting with those outermost first and disconnect at injectors, you can now remove them as a unit with them tied together by the little brackets. Place a bowl under the pump as it will drip from the outlets.
Remove the long injector return pipe and the small pipe around the front of the head that goes back to the pump.Discard the 13 copper washers fitted here.
Now you can remove the valve cover itself, it usually hangs up at the rear where the black air pipe goes to the turbo, you will have to swing it about until you find the right angle for it to come past, in the worst case you can lever the pipe a bit and it will wriggle out. Remove the 6 'O' rings that sit on the injectors and discard them.Make sure you don't lose any springs and washers that sit on the injectors.
Turn the engine so that No 1 valves are rocking and you can then adjust No 6 cyl
( the firing order is 153624, and its always the paired cylinder you adjust i.e.
1-6, 2-5,3-4,) then turn until No 5 is rocking and so on. A standard spark plug socket fits the crankshaft nut.
Now for the technique with 4 valve per cylinder Volvos.
Always assume the valves need adjusting as there is no way to know if the valves open at the same instant from the basic adjusting screw that is familiar to you.
So check there 'IS' clearance at the rocker arm, then slacken the 10mm nut and with one hand press down hard on the bridge which sits over the two valve stems and with a small electricians screwdriver slacken the screw until you feel the bridge is positively down on the other valve, now gently wind the screw in until it meets some resisitance (this is you pressing down hard on the bridge) stop when you feel that point and tighten the locknut.( if you use a big screwdriver you won't feel it contact the valve) Now you have established that the bridge is contacting both valves at the same instant.
Now you can adjust the main adjuster at the rocker arm to 0,40mm (0,016 thou)
After you have done the whole lot then build it all up in reverse.
You will need need the following parts, don't even think about using the old ones as they are guaranteed to leak, I know personally.
6 x Part No 944988 O rings
13 x '' '' 981183 copper washers
When you refit the injector pipes don't tighten them at the injectors, as they will need bleeding.
When you are sure everthing is back in its place, bleed the system as normal then crank the engine until diesel squirts from the injector couplings, now tighten them up and start the engine, it will run a bit lumpy until the injectors clear then it will settle down.
If you have any questions let me know, I have heard of people trying to save time by bending the injector pipes to save some work, but I wouldn't want to be worrying if the pipes are weakened and could crack or split causing a fuel leak or motor to stop just when I need it the most.
Ianj68
18 Aug 2003
Hampshire
www.photobox.co.uk
An excellent and interesting post. My KAD 44 is just about to have its first 200hour service. I'm having the Valves adjusted by the dealer as I'm not brave enough to tackle the job myself. Nevertheless, interesting to see what's going to be done.
Ian.
thefatlady
4 Nov 2005
Hampshire, UK
Thanks Steve. Well written - clear and concise. Sounds a fairly straightforward job, if tedious.
I'm debating what to get next - KAD 300 or D6. I suspect it will be the D6, which seems better for a number of reasons. However, I shall print this and keep it.
John
amf
30 Jul 2002
Surrey
www.crmtechnologies.com
God! I'm probably going to have to get this done at the end of the season. Any guesses on how many hours a fairly competent VP engineer should take to do this on a couple of KAD 300s in a fairly cramped engine bay (Targa 34)?
nicho
19 Feb 2002
Home - Midlands, Boat - South Coast
any guesses on how many hours a fairly competent VP engineer should take to do this on a couple of KAD 300s in a fairly cramped engine bay (Targa 34)?
I'm told it's less than a couple of hours, but maybe that's per engine? So, erm, I guess I don't really know then, sorry. I'm having our KAD 300's done at 200 hours, though I think they can be left for 250 and still be within the window. I'm told of some that have been left for 500 hours due to ignorance of the "problem", and are still working with no problem, but I'm not going to risk it.
In spite of this "extra" service problem, they are still cracking engines - oops, sorry, that sounds like an unintended pun.... why did I start this post??
15 Jun 2006
Hampshire
Thank you very much Spannerman, my KAD44 will need this done at the end of this season, even if I don't tackle it myself I can make sure that whoever I choose to carry out the task does it properley and doesn't try to cut any of the corners you have pointed out.
Excellent artcle, well writen, many thanks.
spannerman
30 Nov 2002
I have done this on a Targa 34 and yes it is a bit cramped, I think I used 6 hrs for the pair if I remember.
Its a bit boring to sit in one spot for nearly a day if you have a double installation, so we usuually worked in pairs and took one motor each then you had someone to natter with, inevitably it became a bit of a race and I think we got it down to 2 hrs for two men with two engines, but I didn't really like to rush this type of job as its easy to drop a part or forget something.
Its not too daunting but allow 3-4 hrs for your first attempt.
JohnRob
12 Aug 2003
Thanks, Spannerman. I've just had tappets done on my Kamd 300s - at just under 200 engine hrs. Will be interesting to see how much time its taken and compare.
spannerman
30 Nov 2002
A KAD 42 couldn't be simpler, just remove the valve covers, and follow the same sequence, but there is only the one adjusting screw on each rocker arm, 30 - 40mins max! But its easier with a cranked 14mm ring spanner to get to the nuts.
bradtarga34
3 Apr 2006
Walton-on-Thames, Surrey
Getting my tappets done again in a couple of weeks on my KAD300's on our Targa 34, it took about 2 hours per engine last time. Mind you, had a nightmare last time as I think the engineer rushed the job somewhat and didn't let some rocker sealant set properly (so they claimed) and dumped half a sumps worth of oil into the bilge on a trip to Ramsgate. Had to stay on a bouy at Gravesend after being almost at Southend and had an extremely uncomfortable night being thrown around with wash and a long limp home on 1 engine following day. I agree with spannerman as not very comfortable being stuck in one position as was watching the engineer for a while and got bored after about 2 minutes, it was very squishy indeed for him! /forums/images/graemlins/tongue.gif
spannerman
30 Nov 2002
Its interesting what you say about rocker sealant, as neither me or any other Volvo technician I know has ever used it, especially on the 44/300 motors, the rubber gasket fitted works just fine if you dry off the mating surfaces. We occassionaly replaced it on the older 40/41/42 motors, but we never used sealant, its just not neccessary. So I wonder what your guy did wrong!
