Al Dickson
Coming home last weekend, The starboard engine on my Botnia Targa 35 has decided it wont rev above 3000rpm.
If I set the engines to approx 2800rpm te revs fluctuate / pulsate between 2800 and 2900 - you can see it on the rev counter and hear the engine note change.
They have done 750 hours and were serviced about 40 hours ago - the engine sounds fine and there is no smoke, temps are normal, oil pressure is good.
We checked the primary filter which was a bit black - we recently dosed the tanks and I have been told the black could be dead bug - however fitting a new filter made no differrence.
Both engines run off the same tank and the Port one is running perfectly
An ideas ?
Alan
An ideas ?
Alan
