Durcott
Hi Folks,
this is a bit of an old chestnut topic, but I just need to check a 'fact', and I'd also be grateful for any comment.
This concerns refitting the glass into its aluminium frame on a Sadler 32.
The frames are quite old, and fairly corroded. I've given up the idea of remaking the original gaskets - it seems likely these wouldn't seal unless the frames were in much better condition.
Having looked up many threads on window sealing, including a good load of information on the Sadler owner's forum, I reckon a product like Arbo Mast is ideal for re-sealing the frames onto the grp.
But what about sealing the glass against the frame? The frames seem to have a shaped rubber insert to hold the glass. This must have perished years ago. (A previous owner then plastered on sikoflex, allowing trapped water to attack the aluminium). Some threads have hinted that a Butyl Rubber sealant could also be used for the glass, but it's not stated definitively. I was hoping I could use a little scrap wood to position the glass, and then use sealant to bed the glass and make the joint waterproof.
Unfortunately it's taking a while to get registered on the Sadler forum, so may I ask if anyone here had any joy in using a Butyl Rubber sealer on a glass to frame application?
Jeff
Jeff
