Just how difficult can it be ......Long Post with bad spelling and worse punctuation
oldgit
6 Nov 2001
Medway
to buy a new boat and go on your first voyage ?
Spend 2 years just trying to get somebody to look at your boat and give up. Spent money on new props.seats,covers, then first person to actually view, buys it.
Travel half way round the UK trying to buy something that is not a tired pile of overpriced smelly mouldy old rubbish.
Buy a boat.
Find somebody able to get your boat back home this side of winter.
Promise the road haulage company the boat will be ready on the slings to grab the boat and run...and he turns up to discover the the useless Marina has not even got the boat off its mooring.
Find that all the local marinas except one cannot put the boat into the water when you want it.
Find the useless marina who were incapable of getting the boat ready on time have done all sorts of minor damage to canopies and prop woodruff key.
Discover prop nuts and washers are well manky and all.
When you run up the engines in the lifting slings on launch,no water from one engine(stripped impellor) quick new impeller fit using a rusty pair of molegrips.
So creep round to RCC with temporary prop fit on one engine and unknown engine cooling situation on tother.
Arrange for new nuts and washers and arrange for boat to go on blocks along with digging out my bit of bar the make up new woodruff key.
On blocks and all new bits fitted in an hour or so.
Wait for tide to return.
On way out prop hit safety stantion and chain and chain that yours truly has forgotton to lower.
Bent blade can be heard whacking back of rudder blade.
Diving team,who just happen to be passing( no really) go down and report the bad news. Grrr.
Ahem. boat straight back on blocks to view damage,
Determind to get boat down to"Battle of Medway" on the following day. so round up club collection of 10Ib flogging hammers and set to work "dressing" the bent blade.
After much hammering and cursing which could be heard for miles around with a very unhelpful audience offering all sorts of useless advice,the job is done.If you stand about a mile away and squint the prop looks sort of alright.
Finger crossed as we go for little test run,seems sort of OK.
Off we go to the big event in the evening and try to drop anchor no luck.
Moor up on Murv, aquire his wifes large water cannon and spend entire evening soak all aboard Loop Lou.
Beautiful Sunday morning breaks bright and beautiful and go off for run down river.
22 knots at WOT and anchor works perfectly. :):):)
Thank you A1 boat transport for your patience and thank you Gillingham Marina for your excellent service.
Job done.
Thames next month,what can possibly go wr****g .
It all came down to having a boat that I could stand up inside, get rid of my "Hobbit Crouch" and something that could outpace a geriactic one legged duck .
Might also be able to keep up at the inter lock Grande Prix !
Wondered what all that banging noise was coming from opposite t'other day. Looks very tidy though. In case you and Merv are wondering we have emigrated from the clutches of the EA and have taken up residence opposite (Pelican). Good bunch there.
I had heard about the prop/stantion interface through the grapevine, the "wooden spoon award" was mentioned in passing.
Still, your prop dressing skills can't have been too bad going by the video posted on facebook of you blatting along over a glassy sea with the sun blazing down. Makes it all worthwhile!!
Beautiful boat, and I'm sure she'll serve you well in the dash back to the moorings :)
Incidentally, I would strongly recommend return of the water pistol, Mrs Murv is not one to take a defeat laying down and seems to have entered into talks with Kent fire brigade... :D
Welcome to civilisation! It does seem a nice club, we popped over there on Saturday to drop a bimini off, great facilities!
I thought these shaft drive boats were supposed to be reliable?
Mind you. We can't say anything. Had to be towed back in on Sunday for the first time in 9 years. Popped a relay (we believe) for the drive which raised it to the top and refused to drop back down again!
Hopefully a quick fix this evening with a new relay.
Sorry but just simp-ly do not believe wot you have just posted
You actually bought something from Volvo.for £2.60 :) Pull the other one.
Don't be daft.
The relay is a Bosch fuel pump relay. Easy enough to cross reference at any decent motor factors.
It is now sporting Motorcraft versions for £2.60.
