Jrc 1000 radar help needed
Obvious question is what size fuse are you using?
Assuming its the correct value and assuming the fuse only blows when the radar is turned on and the fuse has worked ok before this thing statrted - then its probably best to go back to JRC.
I would not fancy trying any surgery on the machine itself.
Perhaps worth checking with handbook that the fuse is the correct value
