Jotun Paint
Steviecracknell
Active Member
7 Apr 2010
Greenock, river Clyde
I have just applied some Jotun products to my fiberglass hull above the waterline. The primer, Penguard HB rolled on very nicely with a high density foam roller, but eventually lost its shape due to the solvent, the solvent resistant rollers were rubbish. I then flatted down the 2 coats of primer using the wet sanding method with 320 grit silicone carbide, nice and smooth. The preperation was good so I continued to apply Hardtop XP with the high density roller, and tip off using the highly recommended x9 synthetic paint brush. I applied the correct amount by roller, then very gently tipped off, but wasn't impressed with the paints flow. I have now left it to dry, and had a look at the finish today, I'm not all that chuffed to say the least. The brush marks are very pronounced, and I now think I've got a horrendous job of wet sanding all of the paint flat, nighmare.
Does anyone have any experience with this paint, and how do I get a decent finish with it.
Cheers Stevie.
Cheers Stevie.
I had much the same experience as you with Hardtop. After an exhaustive period of preparation, the finish on drying was vertical brush strokes stem to stern. Guidelines were followed precisely.
I am not looking forward to rubbing down.
On making enquiries of Shepherds, I was told that perhaps the thinners had flashed off too quickly preventing the paint from flowing.
I am not looking forward to rubbing down..
Thanks for the reply afterpegassus. Though it was my ability to simply brush out the roller mottle. I spoke to Malcolm at SML, they supplied the paint, he was very helpfull, or should I say, salesman like. I ended up buying more paint from him, and looking forward to the delivery of Hardtop AS, thinners, and flow coat.
When I applied the paint, it seemed quite thick, but went on well but didn't flow out, apparently, I should have purchased some kind of flowing agent as well!! Anyway, I've already stripped off the disasterous brush job ( kinda embarrassed incase anyone seen it) just after 2 full days of curing. I used a random orbit sander with 240 grit abranet disks, only problem was the frequent renewal of the disks due to the paint still being a bit soft, but its now gone after 4hrs sanding, just another couple of hours to wet sand with 320 grit, feels like ground hog day. Best of luck with yours.
