Kelpie
I've bought a pushpit to fit my boat, only problem is it's a bit wide. I'll need to cut out about six inches of the (25mm stainless) tubing, and then rejoin it.
Weld?
Sleeve and rivet?
And, cut/join it once in the middle, or cut it at either side? More work but stops the join from being in the middle of a span, so presumably ends up a bit stronger.
Weld?
Sleeve and rivet?
