onenyala
I know this is a much discussed subject but what is wrong with joining 8mm chain with two moused pin back to back 8mm shackles ?
Try running that through your gypsy and you will find out one reason.I know this is a much discussed subject but what is wrong with joining 8mm chain with two moused pin back to back 8mm shackles ?
The only gypsy on board is me !
I would use a bit of climbing/caving kit a Maillon Rapide galv or s/steel epoxy glue the nut or drill and use a roll pin through the nut part of the maillon
Personally I wouldn't do it but if you use shackles don't forget to use seizing wire.
I use seizing wire on any shackle in the mooring or anchor chain set-up, whether it's in eyesight or not !
One thing to beware of is that apparently only 'bow' shackles should be used on moorings ( so I suppose the same applies to anchor rodes ) as these are intended for moorings, straight shackles are not; this may affect insurance if anything goes wrong, I read...
Onenyala, not quite sure what you mean about using bolts ?
For chains which have to go over gypsies there are joining links available:
I would have to bring all the chain ashore to pean over the studs on C links (which have a mixed press on this forum).
For greater strength and reliability many stainless steel shackles are far better.
Here's one that wasn't!
