cmedsailor
I am thinking of buying a used Johnson 3.5hp to replace my "weak" honda 2hp. Anything in particular that I need to know? Shall I expect the Johnson to push my 2.4m tender much faster than the little honda?
I have one & am very happy with it, pushes a 2.4 inflatable very well :encouragement: Mine didn't have a kill cord, just a red push stop so I converted it with a kit from ASAP.I am thinking of buying a used Johnson 3.5hp to replace my "weak" honda 2hp. Anything in particular that I need to know? Shall I expect the Johnson to push my 2.4m tender much faster than the little honda?
You dont say how old or give the model number but presumably from the 2001 to 2005 era in which case ITYWF it is a rebadged Tohatsu.
3.5 hp should be adequate for 2.4m rigid tender. ( 1½ hp Seagull seems to push mine OK)
I believe there may have been a choice of two or three different pitch props so the prop fitted (7½" x 6" being the standard one) might make some difference.
Generally most parts seem to be avaialble
To be honest I don't know how old it is. It's the model with the black-red stipe if that says anything.
My tender is a Hondawave 2.4, the one with the inflatable floor (and little keel).
OK, I know now that it's a 2005 model (I have bought it!). What 2-stroke oil do I have to use? The normal 2-stroke oil for gasolines you buy in any petrol station or something "marine" type? Thanks
Tcw3 marine 2 stroke - not scooter oil
Your choice. It will run on either.
