RAP77
I am having a problem with my 3.5 hp Johnson outboard 2001 model J3RTVS1A01.
Gear box oil is leaking from the drain hole in the bottom of the gearbox, it is gear box oil. I am sure the oil is leaking out via the seal for the shift rod (it is a forward/neutral only model)
I have dismantled the gear box but cannot find a way to remove the bush and o ring from the gear case. It is located in an almost inacessable place at the bottom of the gear case casting.
Any ideas?
Any ideas?
