Billows
Last year after lifting off the boat it jammed.I couldn't pull it past compression.I suspect water got into the cylinder from the exhaust as I may have raised the leg higher than the power head.I took out the sparkplug and it freed up and ran ok. Since then when I try to restart after a period of non use I get the same symptoms.I cannot pull it past compression until I remove the sparkplug and give a good few pulls.Then when freed up it runs fine, starts first pull.It emits a cloud of blue smoke when starting up after a period of non use too.Any idea why this is happening?Any remedies?
