jib downhaul
joeh
4 Feb 2003
asia
hi
has any one experience of using a jib downhaul line for remote pulling down of jib from cockpit. jib is of hank luff. will jib fall nicely on foredeck downwind, upwind, backed or what ? easing of halyard is from cockpit singlehanded. thks.
Rick
15 Jun 2004
Queensland, Australia
Fitted one to our Sailability 24 footer last week - was simply a piece of 4 mm VB cord that passed through a block attached to the stem head, and was then tied onto the head board of the jib. As it happened, we had some trouble with the upper hanks "capsizing" and locking, so moved the attachement down two hanks and it worked fine.
I found that the sail was easily doused by firstly sheeting on hard, secondly opening the halyard rope clutch, and then heading up very slightly as the downhaul was pulled to stop the lower third or so of the sail tangling in the lifelines.
charles_reed
29 Jun 2001
Surprised you
need one - Go head to wind and the whole thing should come down on deck.
I had to fit a downhaul on my forestay - the problem was due to the forestay attachment point trapping #1 halyard. Once that was sorted I had no problem with the thing coming down.
Mind you I've got a Rotostay roller reef which is used for all sails except the solent.
WayneS
21 Jan 2002
Hampshire
I fitted on on my last boat. Just run the downhaul through the top hank before attaching to the head. That way tha top hank will not capsize when you pull it down.
Cheers
Wayne
joeh
4 Feb 2003
asia
hi wayne thanks for the tip. one other thing : do u run the downhaul line inside thru all the hanks ?
WayneS
21 Jan 2002
Hampshire
No, if you run it through all of them you may find that there is too much friction.
Just run it from the cockpit, through a block at the bottom, through the topmost hank and secure it to the head of the sail.
Play around a bit, maybe you need to run it through the top two hanks but I managed with only one.
Cheers
Wayne
