mcalan
Do jelly crimps/gel crimps work On multi strand wire?
BT use them on both stranded and solid wire. They have recently put in new phone cables with several junction boxes and gels.
You can buy several different types, so I guess it's important to match the type and the operating environment.
Jury is out on stranded cable where there is vibration. Theoretically the jelly (an epoxy glue) should prevent any issues. BT see fit to use tham as there is precious little vibration in a junction box.
Tinning, if not in a soldered connection should be the absolute minimum. In any kind of physical connector, screw, crimp or IDC (jelly crimps/ automotive splice etc), excess solder will flow (its ductile) and ease off any/all crimping pressure and cause an unreliable/high resistance joint.
As said above, not a good idea. I would twist and solder the wires, then cover with heat shrink....If possible I will tinn the wire before crimping .
.......all wiring on aircraft are terminated with crimps and never ever soldered.
