Norman_E
Following on from my thread on the joker valves I am wondering if I could solve the flowback problem a different way. I have already converted the flush to using grey water pumped in by an electric pump, and am wondering whether it would work if I stopped using the piston pump entirely and just fitted a macerator pump as close as possible to the toilet at low level, with a small diameter pipe up to the tank. A two way centre off switch could work both pumps, one way to flush, the other way to pump out. The question is do macerator pumps incorporate an efficient valve system that ensures that nothing can flow backwards when they are switched off?
