ianmoondance
New Member
Firstly i would just like to say hello as its my first post here.
Ive spent quite a while searching the net as i have a problem with the rudder on my Jeanneau Fantasia27. The rudder is/was transom hung on two pintles.
I say was because the boat is on a swing mooring in N. Wales and in the bad weather last weekend the rudder, despite being lashed in the central position, seems to have banged hard against the stub of the boarding ladder and shattered just below the top pintle. The bottom section of rudder then sheared the bottom bracket pin and was lost.
I now need to replace the bottom set of brackets and rudder so a few questions please.
Does anyone know where these could be sourced? I am prepared to travel to collect.
Failing that could anyone offer a bit of advice, the existing section of rudder i have left is constructed from 50mm ply, is it likely that the rest of the rudder would have been made from the same material?
So far i have only been able to find 25mm marine ply, does anyone know a source of 50mm or can suggest the best contruction means of bonding two x 25mm sheets?
Finally if i have to constuct the rudder ( a job i dont mind doing) does anyone have the dimensions of a rudder to fit a jeanneau fantasia or have a boat somewhere in N. Wales or the N. West which they would allow me to have a look at and measure up?
I am aware it a big ask for a first post so i would like to say thanks in advance for any help that could be offered.
Ian
Ian
