Jeanneau Prestige 32 starboard leak
gingergrouse56
New Member
3 Feb 2008
Hi, does anyone have a Prestige 32 that leaks through the starboard side window ledge dripping down onto the shelf when you go onto the plane?We cannot seem to find where the water problems is coming from, must be the flybridge somewhere, does anyone have an idea or has experienced this?
Behind the Helm seat is a piece of fabric covered ply which covers the tract from the flybridge and is full height of windows. It is held on by either Velcro or those rubbish plastic gromits which brake when you remove them. If you take it off you can see if the wiring has been Silkaflexed in.
I only know this because I had a very good nosey at SIBS.
Hope that helps
Paul /forums/images/graemlins/smile.gif
j32 leak
We had the same problem and they had to take window out and re-seat it in order to get it right. This was after trying to reseal while in the hull. Good luck.
I have heard that the FB speakers (sealing of) can also be an inlet for the water which leakes in and ponds inside a bit. Then when you go on the plane it runs aft and leaks out at the window. May not be the case in yours, don't know, but thought it worth mentioning.
