weliwarmer
New Member
I couldn't find a Jaycar specific forum to ask about this kit so I thought I'd ask here...
I have some experience of building electronics but this has stumped me.
I followed the instructions in the SiliconChip articles, I am a little colourblind so didn't rely on the resistor colour chart but used a multimeter to check each resistor before fitting. Instead of using the insulator tubing, I covered each high voltage part and the crystal with conformal coating. During the testing step, without the transformers installed, I adjusted and measured the following voltages:
Input : 14.3v
IC pin 5->15 voltage : 4.95v
TP1 : 1.155v
TP2 : 0.5v
2200 uF capacitor: 0v
When power is applied, the green LED comes on for ~3 seconds then goes off and the fault led flashes.
If anyone has any ideas of what I can test/replace to get to the next step, I'd be very grateful.
Thanks,
Tim
Input : 14.3v
TP1 : 1.155v
TP2 : 0.5v
Thanks,
Tim
