oldbilbo
Jester help wanted
Engine charging problem on 'Ella Trout III' presently at 40N 43W. Ideas wanted.....
Lookee here - http://www.oceanracetrack.com/raceplayer/raceplayer.aspx?event=36
Morning All,
Poppa/Dad/Roger is experiencing engine problems*** associated with the "glow plug" and "battery charging" warning lights.
Although the engine starts and runs and his batteries are charging efficiently (checked with a multimeter), the warning lights are coming on and off during engine running?!
A quick search on Google suggests wiring issues with the switch panel/relay/glow plug.
Roger has a Volvo MD2010 diesel engine.
Other than checking/cleaning the wiring/connections...
Can anyone suggest any possibilities for a cure at sea?
I have no means of contacting Roger, however clearly someone has a means of getting a message to Roger.
If you can help please do so!
Thank you,
Guy (assisting Eric and Sandra with Ocean Race Track).
I have a worry with the engine as I have to use it to charge the batteries in light conditions. Last night I noticed two warning lights on, the glow plug and the battery. Checking in the book suggested that the fan belt may need tightening, I did this and nothing changed so I fitted a new fan belt; warning lights still came on. So I started the engine, no problem, and watched carefully what happened:-
when I switch on the battery and oil lights come on.
switch on glow plug, panel light does not come on.
fire up engine it starts immediately.
all lights go out.
after one minute glow plug warning light comes on.
after about 5 minutes battery warning light comes on.
I checked voltage to batteries 13.5 volts being pumped in.
I continued to watch control panel and all lights go off.
a while later glow plug comes on followed shortly by battery warning light.
I think they go on and off all the while the engine is running.
I ran the engine for two hours batteries up to 12.7 volts from 11.8.
Does anybody know what the problem is and can I do anything about it out here?
The engine is a volvo 2010 diesel
