Jam Nuts
Karnic
16 Sep 2015
Hi All
Do I need to lock down the jam nuts in yellow circle of pic. If so should it be done manually and what do they serve for?SAu.jpg
From the cropped photo and lack of description it's slightly hard to tell what we're looking at...
But assuming it's a Yamaha-style throttle/gear connector, the "cracked" bit is just the rubber/plastic cover between the outer sheath and inner cable (and appears to be entirely missing from the lower cable!). There to keep dust/muck out, so desirable to have in place to keep the cables operating smoothly for as long as possible, but not "critical" as such.
If it is such a cable, then yes, the nut should be tightened onto the black plastic connector (to the left of the picture) which connects to the gear/throttle mechanism to prevent it screwing in/out and altering the cable length.
