Cheers I will give that a try tomorrow .I have some similar tufnol cleats on my classic Finn which didn’t grip very well. I took them apart, gave them a good clean and sharpened up the teeth with a file, they now grip fine, so you could try the same.
Maybe this is a multihull paranoia thing, but is a rope clutch really OTT for a mission critical control? I absolutely would not trust ours to anything less. My goto advice would be to replave it with a clutch. Whilst primarily it’s security of the reffed sail in a breeze, it's also insurance that your sail isnt going to unfurl itself and get shredded on your mooring.Similar still available, although not that exact design which I think is a Gibb. I had some very nice ones made of Tufnol which are longer lasting but don't think they are made now although often turn up in boat jumbles and the like. Alternative is a rope clutch but typically twice the price and a bit OTT for a furling line.
If I was going to leave a furled sail on a mooring, I would put a sail tie round it regardless of the type of clutch etc.Maybe this is a multihull paranoia thing, but is a rope clutch really OTT for a mission critical control? I absolutely would not trust ours to anything less. My goto advice would be to replave it with a clutch. Whilst primarily it’s security of the reffed sail in a breeze, it's also insurance that your sail isnt going to unfurl itself and get shredded on your mooring.
Ours has a zipped on cover hoisted up the foil with the spinnaker halyard.If I was going to leave a furled sail on a mooring, I would put a sail tie round it regardless of the type of clutch etc.
Very "Dutch" but a faff if single handedOurs has a zipped on cover hoisted up the foil with the spinnaker halyard.
I often do it solo as Mrs is clearing up inside. Yes, it’s a pain in the arse. I pass the halyard round the winch and bring it out to the foredeck with me..Very "Dutch" but a faff if single handed
Hardly mission critical - not like a mainsheet for example. Cam cleats like that hold pretty well under load - in fact often more difficult to uncleat. On somewhat staid boats like the OPs you rarely need to touch the furling line except to make a deliberate change in sail size. As for unravelling when moored - if you really are worried about that then cleat the tail - but in my experience of using cam cleats on similar size boats they are fine on their own unless they are worn like this one. BTW, clutches are not foolproof and also wear over time.Maybe this is a multihull paranoia thing, but is a rope clutch really OTT for a mission critical control? I absolutely would not trust ours to anything less. My goto advice would be to replave it with a clutch. Whilst primarily it’s security of the reffed sail in a breeze, it's also insurance that your sail isnt going to unfurl itself and get shredded on your mooring.
I couldn’t give a damn if the main uncleats itself unless I’m in 1st place, racing. Then it’s just disappointing. I give very much of a damn if my jib suddenly doubles in area unexpectedly. Then I might need the lifeboat. Therefore my clutches are stripped, inspected and maintained every yearHardly mission critical - not like a mainsheet for example. Cam cleats like that hold pretty well under load - in fact often more difficult to uncleat. On somewhat staid boats like the OPs you rarely need to touch the furling line except to make a deliberate change in sail size. As for unravelling when moored - if you really are worried about that then cleat the tail - but in my experience of using cam cleats on similar size boats they are fine on their own unless they are worn like this one. BTW, clutches are not foolproof and also wear over time.
OK so you use clutches when on the OPs boat a cam cleat will do just as well. Why invent a problem that is not there! If you really are worried, just cleat it off - you don't need to use it for adjustment in an emergency. That is what I do on my current boat as it is not easy to locate a cam cleat or a clutch. When I get lower down my extensive "to do" list I shall invest in 2 of these (I have 2 furling foresails) as I fitted to my Bavaria. LOvely things but they come from Harken so not cheap. More than one way of solving a "problem" but you need to analyse it and choose the best option available.I couldn’t give a damn if the main uncleats itself unless I’m in 1st place, racing. Then it’s just disappointing. I give very much of a damn if my jib suddenly doubles in area unexpectedly. Then I might need the lifeboat. Therefore my clutches are stripped, inspected and maintained every year
