Jackstays
blackbeard
17 May 2003
Hampshire
which, on my little 25' coastal cruiser, are rigged in the normal place, ie along the side decks.
This doesn't seem ideal as, in order to walk along the side decks, my safety line (dog lead) needs to be at least a metre long. More likely, 1.5 m. That's long enough that, if I go over the guardrail wire, I'm suspended above the water and, if I go under it, I'm probably skimming along the surface. As I don't have the arm strength of a gorilla, I can't get back aboard the boat from there. The crew might be able to help, provided I have someone on board with the arm strength of a gorilla - unlikely, especially if sailing single handed.
Yes, I know I'm supposed to go up the windward side of the boat so that if I slip, I fall, so to speak, into the boat rather than into the water. But, in a confused sea, I could fall either way.
So, the jackstays, regarded as an essential safety item, don't do that much for safety.
There's another obvious place to rig the jackstays - on top of the coachroof, one on each side. That doesn't take me as far as the foredeck - there are other solutions, so far as the foredeck is concerned, which include a big cleat (nominally to take the anchor cable) which forms a nice strong point - but I probably wouldn't want to go on the foredeck since the foul-up is likely to be near the mast, and I can reach that easily from a point near the front edge of the coachroof. The coachroof has the major advantage that it's higher than the deck, also slightly further inboard; I can use a shorter dog lead which, attached to the higher point, WILL keep me on board. It will also be easier to clip on to than a stay at deck level.
The proposal is thus to fit a set of jackstays on either side of the coachroof, but keeping the existing ones on the side decks.
Before I start drilling holes in my boat to take the necessary fittings, can anyone see anything wrong with this plan?
Nope - seems eminently sensible to me.
I might even do the same (one of these days)
Or run one central jackstay from the hatch to the mast base.
Clip on from cockpit then you can walk either side up to and slightly forward of the mast
On my 22' boat I fitted harness eyes each side of the mast foot, only a few inches away from it laterally.
A standard harness line reaches the cockpit so I can leave a line clipped on ready, and when going forward swap from a line on a cockpit eye to this line led aft; so I am clipped on before I step out of the cockpit.
From these eyes beside the mast I can also reach forward to the stem for headsail changing.
This set up has the advantage of no jackstay wires to roll under foot, no webbing jackstays to degrade through U/V & salt crystal wear, and they're well inboard to limit my travel if I go over the side or lose my footing.
I'd think such a set-up would work on a 25' boat too, or certainly cover the cockpit to mast bit most often travelled.
