Yeoman_24
I, as I have seen on most yachts, have mine outside the shrouds of my Moody 30 but this season I’m thinking about moving them inside. Easier to go diagonally to the mast to reef and adjust kicker. Thoughts?
No debate. I'd have to step over the guard rails and stand on the toe rail to go forward outside the shrouds.
I can do either which is why I am asking for suggestions.It's a discussion not really worth having as it will totally and utterly depend on the design of the boat...
...that the closer to the centre line of the boat the less chance you will have of going over the side while attached. (tether should be so short you can not go over the side....
Just don't do what I did after re-stepping my mast one year. Port one outside, stbd inside!
... I have in fact considered fixing a stainless loop to the unused spinnaker pole track on the front of the mast (I don't have the pole). By fixing an attachment point about 6 feet up the mast so that I could clip one end of my safety line there, I would have no possibility of going overboard.
Well, if you've carried out a carefully planned experiment to determine which is best you're probably in the best position to report back.![]()
It kinda went a bit like this...
It may depend where your shrouds are, mine are well inboard and its harder to go forward inside, however as I rarely go forward of the mast a jackstay led inside has advantages when working at the mast.
If the mast fails you take the line with it. I prefer not to be attached to any mast rigging. As a result of these debates I will be adding two jackstays down my coach roof passing each side of the life raft to the fore cabin hatch.
