chrishelen
N/A
My Jabsco water pump has started to drip water out of the weep hole. I guess the water seal has disintegrated.
Can I change the seal without removing the shaft?
There are two seals back to back in the pump. There is a space between the two seals. The one nearest the engine is an oil seal, the one nearest the impeller is the water seal. I suppose you could try and prise the seals out by why not just remove the shaft and change the impeller at the same time.
It's a new impeller. I hope I can just 'hook' the seal out and replace it.
I have been mulling this over and decided to take the advice given and rebuild the pump. It's a Jabsco 29450-1101 model. I'm not getting much luck online trying to source the recon kit. Anyone know where I can get it please?
I use http://www.marine-power.co.uk/index.php for pump parts. Very helpful company and competitive on price.
