Jabsco Toilets
JonJon
7 Aug 2004
Right was on the boat last week notced quite a bit of water leaking from around the pump handle shaft. Ah no problem ! have spares fit new seal but notice pump handle shaft has been damaged (small nick probably through someones clumsy use of mole grips) so dont spose it will last long so - right look in manual need replacement shaft apparently included in pump service kit 29040-1000. Back in UK - check Jabsco site no such kit!! But this is the largest marine toilet manufacturer in the world! Like ploughing through treacle at times enit? Sent em an email I wait with baited breath...... /forums/images/graemlins/confused.gif
Well i dont think they are so good now either as i managed to break one of the hinges that holds the seat, phoned jabsco only to be told they are now discontinued and my only option is to spend 54 pounds on a complete seat !
I much prefer the 12 pounds for the two hinges!
29040-1000 is an obsolete part number, replaced initially by 29040-2000 and now by 29040-3000. However, I don't think this kit includes the actual shaft. If you look at the Spares Wizard on JabscoShop, you can buy the shaft and seal separately.
Right PVB thanks my mistake was to look in the manual I should have acted dumb and said I dont have a part number!! Thanks.
