Tam Lin
I fitted a new toilet in Tam Lin a couple of years ago and noticed that it wouldn't pump in water. Then the engine broke and boat came out of the water and the toilet problem became the least of my worries! To cut a long story short I have now got it to work but can't tighten up the jubilee clips enough to stop water leaking out. I am using proper ridged pipe of the correct diameter and have tried warming it up to make it soft so the jubilee clip can bite into it. I have also tried PTFE tape and using a spanner to tighten the clip but am worried that if I tighten any more the plastic inlet fitting on the Jabsco will crack. Is there a knack to doing this? Can I use the softer clear plastic hose instead as I feel that this will seal more easily? Is there something that I am missing?
I have searched the forum index which helped me solve the pump in problem but can't find anything about the pipe work!
