Jeanneau Chris
Hi I hope someone can help me with an unpleasant issue! I have tried to search the forums with no success and it difficult to find the right search terms !
So when we got our new to us boat the toilet, manual jabsco twist and lock type, was backfilling with waste after use, also the pumping was pretty weak.A bit of reading later I purchased A full service kit , fitted it carefully and cleaned everything as I went. All good so far. The backfilling problem has gone, flush now much better and the smell is improved.
All good I thought! However here is the unpleasant bit, if you have a poo when you switch to left and pump in water bits of chopped up poo now flush back into the bowl from under the rim at the top, with the water ! It clears itself after a good pumping but the my wife is going to be less than impressed! Fortunately she hasn’t used this function yet but it’s only a matter of time !
What did I do wrong? I was really careful to follow the instructions but I must have missed something,
Any advice gratefully received !
