Iain C
My 2004 Bav32 has a Jabsco loo (just the standard 29120-2000 model, not a "twist'n'lock" job). She is fitted with a holding tank, and due to accessibility of the seacock (and environmental considerations) usual use is everything goes into the tank, which we then empty on passage out at sea. There's no Y-valve or anything like that, the outlet goes straight into the holding tank, nowhere else.
Unfortunately with the tank at 50% full, we got a second look at some of it's contents which had come back up into the bowl on passage. Both inlet and outlet seacocks were shut. I'm assuming I just need to buy the appropriate service kit and change all the rubber valves and the problem should be fixed? Or is there another issue potentially? As an aside the loo pumps very well, but the pump is quite stiff and squeaky, and the olive oil trick only works for a short period of time.
Thanks!
Thanks!
