meandraft
We have a Jabsco Sensor-Max fresh water pump. This has an in-built pressure sensor that alters the speed to maintain a constant pressure and should switch off once the pre-set pressure has been reached ie. all taps are closed. All of a sudden it now runs continuously and requires turning off via its mcb. I've checked the sytem for leaks but all seems ok. Has any body else experienced this problem. Has the pressure sensor failed?
