TeamSpirit
My water pump is leaking, on inspection I found both o rings on the inlet and outlet had failed and were dripping into the bilge, replaced both of these and thought job done. If only, a small of water is visably coming from the small screw fittings slightly to the left as you look at the front of pump which are located slightly below the pressure switch covered by the rubber boot. Has anyone else experenced this and has a quick remedy without stripping down and using one of Jabasco's Service kits. Meanwhile i've added an additional isolation valve I had in the tool box mid system to provide pressure relief and stop leak for now but ideas for solution and experiences very much welcomed. Ta.
