Jabsco HD Water pump (inbuilt) pressure switch issues?
Blue Seas
29 Jun 2024
Anybody experienced an issue with the inbuilt pressure switch on the Par-Max water pumps? I have recently fitted a new HD version which seems to have an intermittent problem - sometimes it will work fine, charge up the accumulator and then cut-out as normal - other times it will experience rapid on-off cycling (da-da-da-da etc) before eventually cutting out (new accumulator did not change anything).
Suspect a duff inbuilt pressure with but before I return it I thought I'd ask if others had had the same experience?
srm
16 May 2004
Azores, Terceira.
Have had similar cycling, but not so fast, without an accumulator in the circuit. Caused by a either a slow leak in the circuit or by the back up foot pumps not being isolated.
