Jabsco electric toilet decreasing water supply
Nigelpickin
12 Apr 2011
Falmouth
www.cornishcottageholidays.co.uk
Hi
Any experts out there? One of our electric toilets has today started to supply about 1 quarter of its usual fresh water to the bowl; (both during the fill and flush cycle of the process).
Is this an indicator of an obvious fault?
I'd be greatful of any feedback :) we are in Les Sable on Tuesday so should be able to get a tech to look at it there but it'd be nice to know what the problem might be.
Thanks in advance
I can think of three possibilities off the bat, reduction in your potable supply pressure. Solenoid valve getting weak. Control panel timer faulty. Not sure about your control panel but many have an adjustment screw on the back of the control panel to increase / decrease water supply, these are generally used on commissioning to cope with differing pressures depending on the boat's supply but may help you short term.
