maltabob1
New Member
Having fitted one a few months ago , and grateful that Princess included a feed cable in the harness clearly tagged <span style="color:blue"> </span> , had nothing but trouble ! One day it works OK , another day nothing !!!
After months of checking the power supply etc. , it transpires some of the units are ' tight ' and jam ! The motor could have a bit more ' grunt ' ? Apparently the impellors can be a very tight fit . Very dissappointing when they cost the best part of £300 ! Also the plastic Jabsco use for the base unit is very soft , once the screws have been removed you have to be extremely careful on re - assembly to avoid stripping the threads . Why don't they mould in steel inserts to give a more serviceable product ?
Has anyone else experienced the same annoying problems with the motor unit and soft , very soft plastic moulding ? Or do Jabsco sell thousands of plastic mouldings to unsuspecting boaters - in the USA its called ' consumerism ' , an engineer would call it a p-ss poor design !!
