Jabsco 37010 flush
Dino
27 Apr 2009
Ireland
Hi, I serviced my Jabsco 37010 electric toilet yesterday. Fitted the full service kit and put it all back together. It pumps out very well but it is only drawing a small amount of water for flushing the bowl. I tried priming the pump by pouring a few litres of water down the flush hose at the back of the bowl. Also tried holding the button for extended periods.
It is mounted above the waterline so there is no solenoid or vent loop. Should I just strip everything again and use some Vaseline on the seals to ensure its not drawing air?
Mine was slow but I found the feed pipe was kinked.
Funny enough, thats the same as mine since service. enough water to work but nothing like before. I thought it be the way it should as im sure 90% of my tank was filled with the flush water.
