Chrisnewcombe
New Member
Hello,
Recently purchased a 1988 J-24 which has been lovingly dry-sailed (and hence gel-coat only) but now intend to moor throughout season in Portland Hrbr.
Would prefer not to antifoul but cannot commit to taking her out of the water every couple of weeks for a scrub-down, however, will be able to do this once a month and then in between clean via a combination of mask+snorkel and/or cleaning using a length of astro-turf or similar, slung under her ( /forums/images/graemlins/blush.gif hope that makes sense!).
Some queries:
1/ Is it recommended to antifoul the keel and the inaccessable areas, leaving the remainder of the hull to be cleaned as above, or in your experience leave the keel for the monthly clean?
2/ Is it OK to put her in the water without first applying an epoxy coating to prevent osmotic ingress to the core? If not, then can anyone recommend the most suitable product?
I Appreciate that 'to antifoul or not' is a 'personal view' topic but any advice would be greatfully received.
Regards
Chris
Some queries:
Regards
Chris
