30boat
N/A
It's done.I had to overcome a few teething problems.The grinder spindle wouldn't take the side thrust so I fitted an outrigger bearing on the grinder side pulley that engages in a pin welded inside the belt case.I also made the guides adjustable by knobs that turn on threaded rods.The vacuum adapter is made of 1mm stainless plate welded up and faired.
This is a simple machine and I'm already thinking of ways one could be made much more simply.I don't understand how they can charge over £2000 for the commercialy available one.
