iangrant
Just in case we have to sail back from anywhere I've added a mast:
Hmm - your sails might be a bit small for the size of boat you might be able to recyle them off a 420 .... Was it because you don't want to add a keel for the upwind work?
Coo ... Er ... I hope you remember to keep your ballast tanks full - even when planing .... and have you fitted the outboard to the back?<snip>so she is really a big Magregor 26
Oh - and what mastic did you use to fasten the keelbox? Is it the same as mine? If so, do you have the spare Uhu glue - just incase ....The mast is actually telescopic, as is the keel
Oh - and what mastic did you use to fasten the keelbox? Is it the same as mine? If so, do you have the spare Uhu glue - just incase ....![]()
