Deviation
He who normally maintains the boat is away and our aft heads have bailed (or not in this case) on me. I have taken the Joker valve out which was inverted and more open than closed and replaced it with a new one. As I don't normally do these things I put the new one in the same way the old one came out. Doh! Obviously it didn't work so I have taken the new one back out, reinverted it and put it in the correct way. There was a small (less than a mm) gap between the valves after I reinverted it. It's now draining but it's leaking out from the elbow. I've put a jubilee clip around the base of the hose but still leaking as it's obviously coming out from higher up. Any suggestions as I'm rapidly losing the will to live!! Thanks, Samantha
